- Jan 10, 2009
- 6
- 0
- 0
I just found coolant in the top end of my motor (80,000 miles). Gonna drop it off tomorrow to figure out if it's got a cracked head, or just a blown gasket.
Here's a little background on the car. Mostly boltons, h pipe, catback, msd coils, pro flo maf, k&N, and a sct tune. That's about it as far the motor. Anyway, it started smoking about 2 days after I bought it. I haven't put many miles on it. Shortly after is started to smoke i noticed it hard to start. I figured must be water in the combustion chamber. I pulled the pcv valve and there it was. No water on the dipstick yet, but it's deffinately in the top end. I assume it's the heads, or is there anything I might be over looking.
If it is the heads, is there anything I should do while they're off? I'm staying NA and don't want to dump a bunch of money into it. It will be a daily driver. Should I stick with the stock heads, or upgrade to the 99 up heads. Factory cams? porting? valve job? Is there anything worth doing?
Any suggestions will be appreciated. Thanks!
