opinion on starter
the mini starters, if you buy a good one, are awesome pieces with great torque and a lot of cranking power (especially for these NY winters :mad:)
but you should know that they're wired differently and you'll need to follow the proper wiring diagram in order for it to operate correctly... here's the proper wiring diagram:
http://www.fordracingparts.com/download/instructionsheets/FordInstShtM-11000-A50A75B50B75.pdf
whatever you do, DO NOT use the jumper wire method by making a small jumper from two terminals on the starter solenoid, this is a good way to burn out a new, expensive unit, and i've seen a lot of guys on other forums give that as advice and it's wrong and costly
just follow the diagram i provided or one of Jrichter's diagrams and you'll be fine, good luck!
Chris :nice:
The one on eBay isnt too bad of a deal. I just asked for a 92+ starter at the parts store, this way you'll have a lifetime warranty. Then I got a 5.5 feet of wire and some ring terminals and hooked it up.
It sure works a lot better than that chunk of lead Ford called a starter.
ill deffinitly follow what you said on wiring it i orderd it to give it a shot because the guy had great feedback and the price was right so ill let you no how it goes once i have it
Starter solenoid wiring 92-93 5.0 Mustangs or other Mustang with mini starter
+1 for the eBay mini starter. I have one like that that I got off eBay a few years back. It works great and the extra bit of wiring to make it work is cake. Go for it.
I've been using an Autozone starter since '03 when i got my car...no problems yet. It has a lifetime warranty, so when it craps out i'll get a new one free. :shrug:
I guess if i had the money to splurge on stuff like this i would, but the weight savings are minimal and i don't have really high compression so the stocker works fine for me. I'd think about what you really need and whether the cash spent is justified. Just my 2 cents.
well i got it as a 18th bday present from my sister and 76 pplus shipping didnt seem to steep for a bit of an upgrade
