Removing all the air bag sensors and wires.
StreetDreamsGT
449
New Jersey
I recently swapped an 89 tilt column in and I want to remove all the air bag wires and sensors. I've heard there are two blue chimes under the dash and another 1 or two crash sensors in the front? I also want to remove the cruise control stuff so if anyone can tell me where everything is i'd appreciate it....pictures would be nice too, if anyone has em.
You should have 3 crash sensors mounted between the top of the radiator support and the front grill. The air bag control blue box is behind the radio and a/c controls. Remove the air bag dash light bulbs also or it will continue to flash.
Your cruise control servo is in you driver's side fender well, control box in or around the driver's side kick panel. There's a brake petal sensor that you won't need. Your looking about 20 lbs of weight saving.
