I was having some serious issues with my a week ago. Come to find out there is a cable attached to my PCM unit with a dial on the end that goes from 1-6. Only one number works on this that allows my car to run normal.
If it is on any other number the car barely idles and the CE light is on. As I found out after my 3 year old daughter was playing with it.......:/ I did not even realize it was there.
Also, if the number has been changed, I can not pull any codes from the PCM. I am not sure if this disables it or what.
I have tracked the cable to the PCM and the switch comes in behind my glove box as you can see if the links below.
http://i59.photobucket.com/albums/g287/Camarofanatic75/IMAG0055.jpg
http://i59.photobucket.com/albums/g287/Camarofanatic75/IMAG0056.jpg
http://i59.photobucket.com/albums/g287/Camarofanatic75/IMAG0057.jpg
