what the heck is this??
I was having some serious issues with my a week ago. Come to find out there is a cable attached to my PCM unit with a dial on the end that goes from 1-6. Only one number works on this that allows my car to run normal.
If it is on any other number the car barely idles and the CE light is on. As I found out after my 3 year old daughter was playing with it.......:/ I did not even realize it was there.
Also, if the number has been changed, I can not pull any codes from the PCM. I am not sure if this disables it or what.
I have tracked the cable to the PCM and the switch comes in behind my glove box as you can see if the links below.
http://i59.photobucket.com/albums/g287/Camarofanatic75/IMAG0055.jpg
http://i59.photobucket.com/albums/g287/Camarofanatic75/IMAG0056.jpg
http://i59.photobucket.com/albums/g287/Camarofanatic75/IMAG0057.jpg
:shrug:
Yeah, I have the exact same thing on my Cobra. That's the switch that comes with the SCT 4-bank eliminator switch. Positions 1-3 are reserved for three separate tunes, position four is your stock tune, and 5-6 (or 7 in the case of my chip) are all anti-theft non-running positions. The tune will be on the third position if the chip has only one tune programmed into it.
The PCM is oriented in such a way that the harness is at the bottom as it is bolted into the car. There is a hole on the top side on which is a plastic cover. This plastic cover is removed to reveal an extra set of contacts on the circuit board. The chip plugs into this, and the selector switch plugs into the chip. The SCT eliminator chips have tunes preloaded. The only way to change the tune is to remove the chip. I don't know if you can use the SCT X-Cal on their eliminator chips.
Yeah defeinetly a SCT chip. Ive had the instructions for that cable sitting on my desk for a few months.. no time for my car except when my quarters end and have a week off:mad:
anyways...
The sct chip with the flip switch will allow you to select between the stock tune and 3 other tunes. unless otherwise programmed. So position is stock, and the second is your tune.
anyone ever mount theres and where?
anyways...
I described where and how to install the chip in the post above yours. :)
