It was rainig outside this afternoon so I decided to mak a "T" handle for my recently installed TCI ratchet shifter. I looked around the garage and found some scraps of clear and black plexi glass. I glued them together with Contact cement and shaped the handle when the glue set.
This is what I wanted it to more or less look like.
The plexi scraps....
Apply the Cement...
Clamp till dry...
While the glue was setting I made a wood mock-up...
Traced the shape onto the plexy bundle...
Drilled out the finger notches..
Cut the basic shape on the band saw...
Shaping on the belt sander...
And a small drum sander...
Hand sanded with 320 grit and 600 grit wet paper..
Rubbing compound, then polishing comnpound...
A final buffing...
Drilled the hole to mount on the shifter shaft...
Tapped the hole (3/8 - 16)
Finished product...
Finall installed in the car...
There are layers of Black and Clear plexi to make the thickness I wanted.
Took me about 3 hours on a rainy day...
Not perfect, but clos enough.
Apply the Cement...
Clamp till dry...
A final buffing...
Finished product...
