3650 Tranny, FRPP Aluminum DS, MGW Shifter
mklovell
29
Fremont, Ohio
Ok, got my T-56 installed today in my 2003 GT (finally!)
What I have left over:
Stock 3650 (20k miles) - Make offer (I have to be honest, it was starting to make noise when you would set at a stop light in neutral. Shifted fine though)
Stock 3650 Cross Member - $25 (Will throw in with the tranny if the price is right)
SOLD - MGW 3650 Shifter - $125 (put in the car about 10k miles ago. Still in good shape. Has a modified 2005 Mustang Shifter handle included)
SOLD - FRPP Aluminum Drive Shaft - $175 (Put in car the same time I did the shifter - still in good shape)
Everything you need to drop in a 3650 with Aluminum dirve shaft and MGW shifter. Will seperate but make offer for everything in a bundle.
**Note - Shipping will be actual charges to you. I am at 43420. Tranny may be difficult since it is heavy. Everything is in a box and on a pallet now. Weighs about 190lbs.
I also have FRPP 3.73 gear and pinion that was in the car for about 3 weeks before going back to the 4.10's. Practically brand new. $125
Thanks for looking!
It's only when you set at a light in neutral with the clutch out. And only after it's warmed up. It sounds like it's low on fluid and you can hear the gears moving only the fluid is fine.
It shifts fine and only makes noise when setting still.
As I said make offer. I've seen them go for $250 on units needing rebuilt and up to $1250 new.
Still trying to get pics up. (Out of room in my garage - Need to go over to the storage unit..:-)
Photos of DS and Shifter:
how much did u spend to do the t56 but i was reading its kind of a lot of work isnt it. i mean there hydralic where i have a 3650 and thats cable. i want to do it but i was thinking either back to a stock 3650 or if i can find a tko.....annyway whats the lowest u will take for the tranny shipped
