sucking oil? causeing to cut out?
LETHALFORDS
26
im haveing a problem with my car cutting out.
i think its suckin oil throw that vacum line . that goes from the upper intake to the back of the lower intake.
does any body have any ideas?
lik a half a court every lik 5 or 6 weeks
beacuse i changed the upper manifold because my old one was sucking oil up in to the upper intake but it was cutting out. so i canged the upper and it ran good at first then it started cutting out and i thought it was fuel. so i gotta brand new regulator , newer injectors , fuel filter , wires , plugs , cap and rotor. and i think thats it.
and it doesnt start cutting out intel about 4000 rpms and up.
and its been doing its since i changed the upper.
the only vacume leak is the hose to the egr.
the has a b cam with ported heads and roller rockers 70mm throttle body 75 mass air , headers . umm have the smog pump delete and a/c delete.
i checked the timing a while ago when i put the upper back on so idk ill check that tomorrow.
but i think thats all the engine mods
A high RPM miss on a warm engine is usually a TFI module problem. The TFI module mounts on the side of the distributor and provides a ground to fire the coil.
