Just to be sure, put a light coat of grease, Vaseline, or even wd-40 on the tracks. On my '92 Olds, I had rust, then crud build up to such a point where it was nearly impossible to move the window. I was "sure" that I'd have to replace the tracks and the rollers. Nope! It was just rust and grease build up.
If you're near the shore, you may have slat build up inside the tracks along with grease and crud.
It's simple enough to check and do. And, it's better to make sure that crud build up isn't the problem now, instead of buying new tracks, motors, and taking the door apart.
Anyone want to buy a brand new '92 Olds window crank assembly?
Hey, at least I didn't buy the driver's side assembly also (which was in even worse shape).
Also, make sure that the rollers aren't worn, and the tracks aren't bent.
Yea, chances are it's the cheap autozone motor. But, it's free to do what I suggested above.
IMHO, regardless, you should upgrade to a '92 Olds crank assembly! I have inside info on where you can get one cheap.
Plus, the '92 Olds window crank assembly is 0.000001 ounces lighter. So, your quarter mile times will go down by at least 12 seconds, your gas mileage will be better better than a Pruis, and all the chicks will throw themselves at you because you're so smart!
BTW: Yes, the world is coming to an end. I passed up an opportunity to say that Autozone sells cheap cr*p and they suck. Oh wait, I just said it!
Never mind then, the world isn't ending.
