I have a roller 302 with a t5 in my project Mustang. It was running fine for the month I got it running and the couple of weeks I drove it, although it did run a little rich. One night I kind of got on it then the car started stumbling then backfired and I had to keep giving gas and it kept dying when I put it in gear. When I got home I did a compression test which was fine and I started it the next day it ran "okay" but sounded kind of off and when it gets put in gear it dies. I tried to start it the next couple of days and it would start run rough and sound like it wasn't getting gas then die unless you gave it gas, and wouldn't start again unless you let it sit for a while, and it would backfire sometimes through the carb when I attempted to start it. I pulled off the timing cover just to verify everything was fine and the timing marks lined up and they did, and also checked the distributor to check that it was at TDC and it was. Then I decided to just re install the distributor (which is a new hei unit) and re time the car. After I re installed at TDC and set the timing and it ran fine for a while and even even turned it off and started it again to make sure. Then it just started idling rough and died again. When I started it again it idled rough then I would loosen the distributor to move it then it got a little better then just died again. I really don't know what could be wrong now I have a new timing gear and chain so there not worn. The car keeps on losing timing and I don't know why.
