96 cobra missfire
94GTHO
200
Richmond, Va
Hey stangnet, i have a little problem. My girlfriend got this cobra not to long ago and it was running fine. THen one day it started getting a miss to it. There was no check engine light. So we threw some octane booster in it thinking that a lower octane gas might have been put in on accident. Seemed like it helped but then a few days later when we take it out again the miss is worse. Still no code. I took the plugs out and noticed that the passenger side plugs were different then the driver side plugs. I know this could be the problem and got new ones just havent put them in yet. Do you guys know of anything else it might be besides the wires? Just want some input. THanks
I wouldn't mind changing my own plugs every 10k but on the GFs car, I'd never hear the end of it. "didnt you just put spark plugs in it?"
"it acts funny at redlights"
"it takes longer to crank"
That said i have copper cores in mine.
So when I change out the plugs I am supposed to keep them 2 different ones. When I went to advance auto parts to get the plugs, it only called for the sp342 which was motorcraft platinum finewire. It never said anything about two different kinds. And also, with the old plugs, the ones on the left look like when tightened they would sit higher away from the piston then the ones on the right
Not sure about the length thing.
Platinum is not as expensive as it used to be. You only need the platinum on one electrode so ford only put it on one electrode. 4-6-8 plugs times millions cars means they saved several million dollars. The prices have come down and now they put the platinum on both electrodes.
Yes. A double platinum plug should last another 100k miles if it doesn't have any other problems. Motorcraft plugs are well respected, Autolite a close second. Personally I dislike Honeywell who is the parent company of Autolite. Motorcraft double platinum FTW!
