what to set fuel pressure at?
what psi do i set my fuel pressure regulator to? isnt stock like 44psi?....
:SNSign:
The injectors are designed to operate across a nominal pressure drop of ~39-psi. At idle, if your engine is pulling say 18-inHg of vacuum so the idle fuel pressure should be set to about 34- or 35-psi or so. With the engine off, the pressure should rise to ~39psi.
is that with the vacuum line on or off?
If the engine's not running, it doesn't make a difference. If the FP is to be set with the engine running, it can be done one of two ways:
1) Disconnect the vacuum line and expose the FPR to atmosphere. Set the FP to 39psi. Re-connect vacuum line.
2) Leave vacuum line connected and use vacuum or MAP gauge to determine manifold pressure at idle. If you know the inHg (inches of mercury) pulled at idle, you can roughly determine manifold pressure with:
Code:
MAP ~= (29.92-Vac)*0.491154
So if you're pulling 18inHg on a vacuum gauge, there'd be ~(29.92-18)*0.491154 or ~5.86psia in the intake manifold. Subtract this number from 39 to get the value you want to set the FP to (in this case, 39-5.86=33.1psi).
It's probably easier just to pull the vacuum line and set it to 39psi. :|
i dont know if 39psi is enought?
i set it at 39 with the vac line off, and is breaking up really bad under acceleration with load, and it has terrible throttle responce, i dont know if it matters, but the car does have a walbro 255 pump, 24lb injectors, and was dyno tuned on the stock fuel pressure setting.......
Can you leave the gauge connected and drive around a bit (carefully) with it to see what the FP is doing under other driving conditions? Are they FRPP injectors? And, silly question, but you're setting it to 39-psig, not 39-psia, right?
i am leaving the gauge on all the time, they are denso injectors, and i have a autometer gauge that i set it to 39.......
