what psi do i set my fuel pressure regulator to? isnt stock like 44psi?....
:SNSign:
so with the engine off, and the key on, i should set it at 39psi?
is that with the vacuum line on or off?
MAP ~= (29.92-Vac)*0.491154
i dont know if 39psi is enought?
i set it at 39 with the vac line off, and is breaking up really bad under acceleration with load, and it has terrible throttle responce, i dont know if it matters, but the car does have a walbro 255 pump, 24lb injectors, and was dyno tuned on the stock fuel pressure setting.......
Can you leave the gauge connected and drive around a bit (carefully) with it to see what the FP is doing under other driving conditions? Are they FRPP injectors? And, silly question, but you're setting it to 39-psig, not 39-psia, right?
i am leaving the gauge on all the time, they are denso injectors, and i have a autometer gauge that i set it to 39.......
So what does the gauge show during driving, especially when the car is acting up?
What does it read at idle? At WOT? At part-throttle?
