suggest a nitro kit for me
which is better wet or dry? is there an adjustable kit? id, like to be abler to do a 100 shot put it on the 302 for now but next year i wanna go 351 so then if i could do a bigger shot itd be nic
i run a wet kit from zex. as far as being adjustable, its got interchangable jets from 75-125 shot. every brand makes wet and dry kits, imo wet is safer (as long as you follow directions and avoid fuel puddling in the intake) especially in your case as it seems you may not know a ton about nitrous. the zex kit comes with a nitrous management unit, you just run your lines into the box and its set to spray at WOT. very simple kit.\\
do a search for zex nitrous installation and you should see a thread i made a while back showing the install.
i have a friend that recently put a kit on his i think it was nos kit so installation shouldnt be to bad with his help
anyone have pictures or ideas on where to install the bottle?
hmm i dont really understand where u mean, i forget where my buddys is i thoguht he said it was under the cowl vent or soemthin tho
....i think your very confused
if your asking where to mount a purge line, then sure under the cowl vent is fine, if your asking where to mount a 24lb bottle of nitrous oxide, then the hatch/trunk is the only way. unless hes running a sneaky pete system of some sort.
i think either you or your buddy are very confused.
read the link i posted. it will tell you how to set it all up step by step.
ok i see whatr ya mean although i have no room in my trunk i have 2 amps and 2 subs and battery in the hatch and 4 pt roll cage
ok. is your car a notch or hatchback? something will have to be moved, unless youd like to mount it in your back seat and then its VERY unsafe and not track legal.
its a hatchback i doubt its track legal anyway the battery case aint really even bolted down, maybe it can be mounted on the right side back near where the lights are in the hatch? and i think the bottle i will use is 10 lb bottle
my friend knwos his stuff i jsut havent really looked at his car much he has whole trick flow hci kit put it in himself nitro put in himself
oh i thought u meant a bigger bottle or soemthing, but yea ill have to find soemwhere to mount it and i would like it track legal i guess, for it to be track legal how does it have to be mounted usually?
nitro with the bitchtits for the win
looks like the air intake tube style is the easiest to install?
I like this zex kit, its affordable as well, i heard dry kits are better for 5.0's? whats the major difference in wet or dry???
Zex 82015 - ZEX Dry Nitrous Systems - Overview - SummitRacing.com
anyone else use this? id like to do the 100 shot
im worried about the computer chip and advanced timing though
dry shot is JUST nitrous, wet shot is nitrous AND fuel.
no need for a computer chip, and youll need to RETARD your timing, not advance it. ive got mine at 10* and have yet to have a problem.
