Red line Heavy ShockProof gear oil for the rear ?
Killa
1,006
56
49
Just wonder if any body using this oil for their rear end mustang. I know redline is not recomment on mustang tranny, but the the rear, i jsut wonder.
* Fully-synthetic formulas created from polyol ester base stocks, offer excellent lubrication under extreme conditions
* High viscosity-index (VI) to provide relatively constant viscosity and film thickness with varying temperature change
* Ester base stocks and friction modifiers provide additional slipperiness to lower operating temperatures by reducing the sliding friction in hypoid gears
* Superior shear stability and reduced oxidation compared to other synthetics and conventional gear oils
* Exceed API GL-5 specifications
* Engineered to provide the highest degree of protection and improvement of differential efficiency for better mileage, longer drain intervals, and less wear
wat is best gear oil to use for my rear diff ? i been use vavoline 80w90 for last 2 year without any problem. Should I stick the same thing ? the reason i ask because its getting alot colder here now.
I remember I did search few year ago, when i just bought the mustang, I came across this thread, and it say some one is talk to Tremec repesent , and they say never use redline product on their tranny.
Upgrade I did call redline today, and they say they not recomment me this product for my rear, they say 75w90 is better for my application.
Can a 98 gt use 75w/140 mobil 1 syn gear oil ? i know 98 ford recomment 80w90, but it change to 75w140 after 2000, I just wonder if i can use that ? thanks
