629RWHPstang New Member Apr 28, 2009 19 0 1 NY Dec 18, 2009 #1 Dec 18, 2009 #1 outside now trying to take off the gear on the distributor that runs off the cam its a 90 GT i took the pin out but the gear is not sliding down.... any help would be great guys!!!
stykthyn I want to measure mine. It doesn't look that tall. 15 Year Member Jul 6, 2006 5,232 2,652 223 gainesville Dec 18, 2009 #2 Dec 18, 2009 #2 try heating it.
629RWHPstang New Member Apr 28, 2009 19 0 1 NY Dec 18, 2009 #3 Dec 18, 2009 #3 it there a c clip ring im not seeing of something?
Duncan McDougal Active Member Aug 17, 2005 99 0 27 Gainesville, FL Dec 18, 2009 #4 Dec 18, 2009 #4 It is because it is pressed on. If you took the pin/pins out and it is still not coming off then either heat it of use a press.
629RWHPstang New Member Apr 28, 2009 19 0 1 NY Dec 18, 2009 #5 Dec 18, 2009 #5 Duncan McDougal said: It is because it is pressed on. If you took the pin/pins out and it is still not coming off then either heat it of use a press. Click to expand... yeah did the heat thing and no dice... going to try the press tomorrow
M mr_josh Founding Member Oct 11, 2000 87 1 9 Dec 19, 2009 #6 Dec 19, 2009 #6 Like others have said, it is press fit. They sell tools designed for removing it if you don't have access to a press. Google "distributor gear puller".
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Dec 19, 2009 #7 Dec 19, 2009 #7 Another method is to use a bearing splitter with a screw-on puller (that screws into the bearing splitter).
