I have a question, why is it that the 03-04 Mach 1's seem to outperform the 96-98 Cobra's in stock form. According to what I have found, the 96-98 Cobra has a curb weight of about 3400 lbs and produces 305hp @5800rpms and 300 ft. lbs of torque at 4800 rpms. Whereas the Mach 1 with an almost identical curb weight produces an identical 305hp at 5800rpms and a slightly higher 320 ft. lbs of torque @ 4200 rpms. These numbers come from the same type of engine also, a 32 valve DOHC 4.6L modular V-8. What am I missing here???? The cobra is said to run 13.99 stock, whereas the Mach is good for extremely low 13's stock. I remember when they first came out, Ford enlisted a professional driver and a set of full blown slicks to run 12.xx something (high 12's) bone stock. Any thoughts are welcomed/appreciated!
- THAT was the comparo OFTEN discussed on the various mustang message boards on the 'net. Not gonna sidetrack this thread, but the 3.27 IRS (ie - wheel hop) equipped 99/01 cobras did not fare too well against the solid axle 3:55 geared 03/04 Mach 1s in a STOCK Vs STOCK race.
