Are those vacuum lines? If so, that could be some of your problem. You may have a bad vacuum leak. But did you do anything to the car before it started running crappy? Did you disconnect some vacuum lines and forget to reconnect them? If I remember correctly didn't you say the car suddenly started running crappy and getting bad mileage and you hadn't done anything to it?
I also have a 92 Mustang Gt and I recently had bad fuel mileage issues and after talking to a bunch of guys on here, I think I have my problem solved. Some of my issues you might be experiencing also, but it also sounds like you have different problems too. I was using a half a tank of gas and only going 100 miles. Long story short....I had put in NGK platinum plugs instead of good ole copper plugs. Someone on here advised me to use Motorcraft or Autolite copper plugs, since copper is a better conductor of electricity. So I took their advice and yanked out the platinum plugs and put in some Motorcraft copper plugs. Also I pulled the codes on the computer and I found a code that told me my EGR Vacuum Solenoid was bad. So I changed my EGR vacuum solenoid (the top solenoid (there are 3, not sure what the other two are for) mounted behind the passenger side shock tower). After changing the plugs and EGR Vacuum Solenoid, my problem was solved. However, I didn't have the bucking issues and bad driveablilty you're having, just the bad gas mileage. If I remember correctly, I think you mentioned you tuned it up. What kind of plugs did you use? Also, you're really causing yourself alot more stress by not pulling the codes off the computer. You might answer your own question and solve your problem if you pull the codes. Do that before you do anything else and then get back to us and tell us what codes the computer had. Just trying to help....
