oil pressure
It threads into the stock location which is above the oil filter, it will be easy to spot, use a copper line instead of the platic one.
i used a t-fitting on mine so i could maintain the factory sending unit and still install my mechanical gauge.
you can buy a brass t-fitting at a home depot or hardware store.
be careful with straight 30 weight until the engine is warm. you will break the oil pump drive shaft if you push on the engine before it gets warmed up.
Definitely don't use the plastic one. I had one spring a leak and spray oil all over the hot header. Smoked like hell! I bought a copper line and then slipped it inside a length of rubber vacuum hose for extra protection. Or buy a braided line if you got a few extra bucks.
