i have a coolant leak on top of the timing cover on the drivers side.
I'm not 100% sure where its comming from so i dont want to start replacing stuff without figuring out what the cause is. I changed the timing cover and intake gaskets when i did the H/C/I swap about 3 years ago. i tried letting the car idle with the puddle still there and cleaned up but i didnt see where its coming from. no bubbles or anything. i tightened the timing cover gasket and i think it made it worse.
The oil is not milky so thats a plus
If i rent a coolant pressure tester, would help me find out where its coming from?
heres some pics of the leak
The oil is not milky so thats a plus If i rent a coolant pressure tester, would help me find out where its coming from?
