So I picked up a Fel Pro exhaust manifold gasket set from Auto Zone again going for the cheap stuff. I used a razor type tool to scrape the old gasket off (man so much easier to work on with the engine out of the car, LOL), and a metal ruler to check my heads and see if my exhaust manifolds were worped, and they look good. Then I spent some time cleaning the old bolts with a wire prush and WD-40. And I chased the threads in the heads, [hey that rhymes] and cleaned them out really good, yes should have done it when the heads were off, but oh well. I also took the wire brush to the exhaust manifold and got some of the rust off of it. So before I put them on I have a few questions.
QUSTIONS:
The gaskets have a shiny metalic side and a dull side, which side goes towards the engine, which side towards the exhaust manifold or header? Two AutoZone "experts" had two different opinions!
Do I put any type of goop on the gaskets or do they go on dry? My guess would be dry.
What goop if anything do I put on the exhaust manifold bolts before screwing them in. I know I can rule out LockTight, jk.
As I can no longer buy replacement bolts, can I replace a broken exhaust manifold bolt with a grade 5 (3 notches on the head) bolt, or should I use grade 8 (6 notches on the head). Please see picture below of the old bolts and a new grade 5 bolt..
I wonder if the rust will come back on the manifolds unless I coat them with something?
thank you and you can see more of the project here:
Small Block Ford 302 V8
QUSTIONS:
