Anybody use these Taurus 3.8 replacement fans?
I use the 3.8 Taurus fan, about 30-40 bucks from a j/y. It does a pretty good job (even with the AC on in 100 degree heat) along with the DC controller and a larger alum. radiator. The shroud is not a perfect fit, I actually took some sheet metal and filled in a few gaps. If I had it to do over I would consider the Contour twin fan.
And Ramcharger was not a reference to the vehicle (Dodge Ram). The Ramcharger fans look much like the fans out of a Dodge Intrepid.
I just pop-riveted two "L" aluminum angles on the top of my shroud where the factory bolts go and drilled for the stock mounting bolts and then used a cutoff wheel to slot the bottom of the shroud to accept the stock mounting clips - the shroud was a perfect fit on my stock 2-core radiator.
