HELP! Bouncing off rev limiter w/ predator tuner
JLstang351
528
atl,ga
car is a 01 GT w. auto trans with 3.73 gears. Ive manually went in and set rev limiter at 5800. even putting shift points at 5600 and pegs at 6k and will bounce on limiter for 2 seconds before it shifts. Any help is much appreciated.
BTW... it did this on the diablo canned tune before i ever touched anything
^ you got it, set the rev at 6200 and shift points at 5800, this shoud give the slow ass 4R70W time to shift at around 6100/6200 or so !
Also do you have a shift kit or J-Mod ?
The AOD is VERY slow to complete a shift and on the 1-2, you still aren't giving it enough time. You are reving very quickly through 1st and you find the rev limiter before it can complete the shift still.
What was the factory shift point before you started playing? I think it was rediculously low, like 4500, but then it actually performed the shift at 5500 due to the time delay to shift. Set the shift point to 4500, and work your way up until the actual shift occurs when you want it to.
