Ok, this has been an ongoing problem, but I have had multiple things going on at once (KB front seal....). I have been fixing them one at a time, but back to the major issue again.
I have had a fuel and vacuum issue for a little while. I think I have narrowed it down, but I need some opinions before I start tearing everything down again. First, I started having a random misfire. It does not throw codes (infact since I put my engine back together, I have had 0 codes...even for my o2s). The misfire starts after the engine is warm. It is lessened by running the A/C. A secondary problem is that my fuel pressure gradually rises over time until it levels out at about 60.
Here is what I am thinking. The vacuum system is connected to the fuel tank via the evap system. I am thinking that I either have a leak in my gas tank....filler grommet, fuel hat seal (yes, the pump was upgraded almost 2 years ago but this has been going on since around that time). I do have the strong smell of gas for about 2 days in my car after filling it up (30 mins of idling = quarter tank). I checked the Boost-a-Pump....voltage is normal.
My major problem is no codes and the randomness of the misfire. I would figure that if I had a problem with the evap system or gas tank....I would get a code. I also figured that since I do not even have 1 rear o2 sensor plugged in, I would get a code....none.
If anyone has any other sugguestions, I would greatly appreciate them. I am disabled due to the Army, and it is a pain in the ass to do stuff over and over because it takes me forever. If I can do it all at once, it would be great!
Thanks!
Thanks!
