Edit - I feel kind of stupid. I went in and looked at my Diablo today and the neutral idle is set to 736. I installed that tune about 6 months ago. Not sure why my mind was playing tricks on me. Probably because my odometer flipped out around that time and I thought there was something with the cluster. Is 736 too high? That's what was installed with the default "87 Performance" tune. What do you guys recommend?
Car looked like it was idling around 745rpms (Diablo real time) which seems abnormal if I recall. It was ran for a few seconds with the air filter and MAF off but it stalled of course. Also ran for a bit with the vacuum hose off. The car is still burning off all the marvel mystery oil that was sucked in through the vacuum on the plenum so we could trace an exhaust leak. Hopefully that stuff burns out soon because it smells like crap and leaves the cars behind me in a good cloud of smoke
Car also hasn't ran through it's readiness test since the battery was disconnected recently, so it is not throwing any codes besides that. Was throwing a code for the output shaft speed sensor but I cleared that and everything seems to be working fine on that matter (speedo, odo).
While I have your attention, my mufflers are leaking on both ends where they meet the flow tubes, where that c-clamp is. What's the best way to seal that? Some kind of exhaust putty I heard about, or that exhaust wrap?
