car wont start sometimes,had to cycle key
89llx
5 Year Member
Aug 31, 2009
302
I have a 95 gt sometimes it wont start, I checked fuel pressure and it was low ,so cycling key did pull up the fuel pressure to 38, on my gauge, so is my fuel pump bad?
thanks
Does it crank when it won't start?
When you don't cycle the key and it won't start,
if you cycle the key, does it start immediately?
yes, it cranks, I put a pressure gauge on the fuel rail and when I first hit the key I get 20 pounds of fuel press, after I cycle the key it will go up to 38 pounds, yes cycle the key fires it up
thank you soooo much!
If you have fuel line crimping pliers, you can try to ascertain where the issue is. The most likely sources are a weak check valve or the FPR.
Otherwise, you could prime it a couple of times before trying to start it or let it crank for a couple of extra seconds while it builds pressure.
Odds are it's the pump...super common on these cars. A new pump will cure it for awhile, then it starts all over again...been there. Everytime it builds 38 psi or so it'll lite right off, anything less it cranks...I use my fuel pressure gage on the cowl and can see it.
Its a pain to change and letting it crank is a drag to boot....use the 3 time key on trick til you feel like getting at it. Mine did it for years...it's more aggravating than anything else....specially if your in front of a bunch of Chevy guys and it just cranks.....:D
Sometimes my 94 fires right up, and others i have to crank it a little bit, or even a few times. I can definitely hear my fuel pump whine pretty good while driving. I also feel that it lags sometimes. Also, do not have a pressure regulator. Could that be a pump issue?
Be assured you have a FPR if not aftermarket then the OEM unit.
