hi i have $1500 i want to spend on performance parts what are all the best parts that would at up to that on a 1997 mustang gt
sorry for the bad grammar pi swap how much power to the rear wheels will that give me? and subframe? whats that?
PI swap (intake, heads, cams) with no other mods would put you in stock 99-04 GT range (220-225rwhp). Not only that but every other bolt-on you do would yield more porformance with the PI parts. PI swaps can usually be done for pretty cheap.
Subframe connectors are essentially metal bars that connect your rear control arms to the fire wall of the car. They stiffen up the suspension quite a bit and vastly improve ride quality and handling.
Did you get your's put on yet? What do you think?
No not yet. I haven't even unpacked them yet.
I don't have the car right now. Im having some LT's, mid-pipe, and a new rack/pinion installed. Subframes are next as soon as I get it back.
- AC lines on the passenger side and brake lines on the driver side are very close to the headers). Push everything as far away as possible and consider wrapping things local to the headers in heat reflective wrap/tape.
