Keeps Overheating
lxman
279
Avondale, AZ
My car keeps overheating. I flushed the coolant system replaced the t-stat (195 degree), and put new coolant in. I drove it 40 miles the it overheated again. I live in AZ where it is hot. Right now this is the only car I have working. PLEASE HELP! Thanks! :(
is your fan working ? is it a stock fan ? possible head gasket problem does the coolant smell like fuel,or exhaust . is the chin spoiler installed ?lots of things can cause overheating ?what does the inside of the radiator look like?any scale inside ?
Ok, sorry I forgot to put all that in I was in a hurry. It over heats on highway. Original 4 banger radiator, mechanical clutch fan. I don't know if the clutch is bad or not. No fan shroud on it. If I should upgrade just let know what and where to get it on a budget. Thanks guys!
4-banger radiator? 2-core or 1-core?
The non-ac 4-bangers come woth a single core radiator that is too small for a 5.0. The ones with ac have the standard 2-core.
Overheating on the highway could be caused by not having the lower radiator deflector in place. Is yours present?
Ok so I definitely need to upgrade my radiator then and get a shroud. I think the defletector is on there. What does it look like so I can make sure. My lower front bumper is missing a 1 ft section right in the middle. It drives great, just keeps over heating. It is driving me nuts! Where can I look to get a bigger radiator for cheap. I just moved to AZ and have like no money.
If your car overheats now, it will certainly overheat with a 160.
My preference is the 180 mr gaskets stat, but if your thermostat is not bad, it won't prevent anything right now.
Get a good radiator and the correct fan shroud, that should probably fix your problems.
Im in central florida and we are getting up to around 98 in the afternooon right now. I am running a stock gt radiator and a 180 degree t stat. In december I did the 3g alternator and electric fan upgrade. It runs great, the thermostat opens around 180 degrees, the fan turns on at 200 degrees and off at 190 degrees. Autozone is supposed to have a pretty decent "heavy duty" radioator for a v8 fox. A fan shourd is a must. Grab your fan and spin it the more freely it spins the more worn out it is. If you dont want to do an electric fan swap right now(3g upgrade is a must) you can switch the stock fan to a flex fan. I ran one of those for a couple years without any problems if yours is worn out. How old is the water pump? The impeller could be spinning on the shaft.
The fan function isn't necessary when driving at highway speeds 'cause there's enough ram airflow through the radiator to keep the engine cool. If the engine overheats only under these conditions with normal temps. in city driving, there can only be two reasons. Either the airflow through the radiator is being obstructed (big foglights, custom grille), or limescale/rust inside the radiator is preventing sufficient coolant from circulating. Your problem is the latter, not the fan.
radiator sounds old and too small, i would upgrade to a decent rad make sure u have a shroud and put a 180 therm in dont use that mr gasket high flow crap i had a 2 month old one overheat my new 331 stroker cause it would not open at any temp. Get a 180 stant and drill a couple 1/8 inch holes in the flange for a little extra protection just incase it wont open u still have a little coolant flow into the engine, a 160 therm only means it opens and flows coolant into engine at 160 instead of 180 that wont change the final temp car running at. My car runs around 200 in traffic in the summer and i have a 180 therm. no overheating running great:nice:
All thermostat brands fail or even show up DOA.
This is why you always test it before you put it in.
The mr gasket is much less of a restriction when it's open.
