Anyone Used One Of These Radiator Hold Downs With The Griffin 31x19?
yes
I have not used one of them, but it looks good to me. I'll take one in gloss black, please.
To answer the OP, I use the stock brackets on my 31x19 Ron Davis radiator. I used a little rubber tube to keep the radiator from rocking back and forth, but it's not a clean solution.
I will post pics when I get mine, I couldn't decide between black and satin aluminum but went with the latter, hope I didn't make a bad choice!!!
I've used the stock brackets on my 31x19 for years, just wanting to change it up some!!!
Sorry for the delay, I also removed the two bolts on top of the air bag sensor. Also apologize for the horrible picture I'm posting but cell phones and bright light doesn't work(no camera does!!!) but anyways:
I also put a piece of foam style tape under the lip to make sure it doesn't rub any holes in anything being metal to metal like it was. Overall, worth the $2x I paid, I don't think I could of made one for that.:flag:
-Edit-
I bought that distributor from the parts store and it had no place to put wires on it!!!!! ;)
I think u got ripped off... Are you running AEM? what coil packs are you using?
Yep, truck coil packs. Wish I had a fancy way of mounting them and have them look good without changing intakes. I was going to mount them on the end of the exploder intake but never could figure out what I would do on the passenger side so I mounted them on the strut towers until I change intakes down the road.
I think I heard AEM quit making and supporting the EPM now, lol. So I expect mine to go out any day since that's usually how AEM stuff does.
i run a UPR one, which is similar/same. i had to notch out a section to fit my airbag crash sensor.
Me too, but no airbag on my '89.
I used an extra piece of the door jam foam strip that I had in the garage. I don't know what they call that stuff. It's the gasket that goes all the way around the door opening, between the door and the body. I had an extra piece, and it clamped onto the radiator hold down perfectly! It holds my Fluidyne radiator nice and tight, without scratching anything.
