maf completed....issues
hey guys,
my i just switched my car to maf but when i was done car would not start. i just replaced the battery today and it started up. now my amp light will not shut off. i put a 3g alt in well over year ago and followed the wiring instructions from this site. i have not had any charging issues after i did the 3g alt. now i converted my car to maf and the battery guage will read right above the read line. can this be related to the maf converstion in any way?
also, when my car was running today for the first time since the maf converstion smoke was coming out of the oil fill cap when the cap was off. my car has never done this before. i smelled the smoke and it smelled a lot like gas. again this is the first time i started it since the conversion and i have not driven it yet since it is raining today.
i got all my maf stuff from a 89 gt. my car is an 87 gt
any advice on why my amp light is on and why smoke is now coming out of the oil fill neck since the maf converstion?
the new battery i got is rated at 610 cold cranking amps and the battery i took our had about 700. could that be the issue?
thanks
Thanks, all I did was pulled the tubing, meter and harness from an 89 gt 5 speed. I got a new cpu from o reilys
and followed the wirimg instructions from the mass air conversion write up on this site. I have not done the steps for vss wire or fuel pump wire yet.
Yesterday was the first time I started it and I just let it idle and smoke that smelled like gas was coming out of the oil fill neck with cap off. All the maf stuff should be stock, and the cpu I got was for an 89 gt 5 speed. The mods I know I have r, roller rockers, ud pulleys and or h pipe.
Please let me know if u nwed more info and thanks for the response
Never, never disconnect an alternator from the battery with the engine running. The resulting voltage spike can damage the car's electronics including the alternator.
Alternator troubleshooting for 86-95 5.0 Mustangs:
Do all of these tests in sequence. Do not skip around. The results of each test depend on the results of the previous tests for correct interpretation.
Changes in wiring for a 3G alternator are in red.
64898d1292685364-new-alt-battery-still-have-charging-issue-87-93-alternator-wiring.gif
Engine off, ignition off, battery fully charged.
1.) Look for 12 volts at the alternator output. No 12 volts and the dark green fuse link between the orange/black wires and the battery side of the starter solenoid has open circuited.
3G alternator: Look for 12 volts at the stud on the back of the alternator where the 4 gauge power feed wire is bolted.
No voltage and the fuse for the 4 gauge power feed wire is open or there are some loose connections.
2.) Look for 12 volts on the yellow/white wire that is the power feed to the regulator. No 12 volts, and the fuse link for the yellow/white wire has open circuited.
Engine not running, ignition on, battery fully charged.
1.) Alternator warning light should glow. No glow, bulb has burned out or there is a break in the wiring between the regulator plug and the dash. The warning light supplies an exciter voltage that tells the regulator to turn on. There is a 500 ohm resistor in parallel with the warning light so that if the bulb burns out, the regulator still gets the exciter voltage.
Disconnect the D connector with the 3 wires (yellow/white, white/black and green/red) from the voltage regulator. Measure the voltage on the lt green/red wire. It should be 12 volts. No 12 volts and the wire is broken, or the 500 ohm resistor and dash indicator lamp are bad. If the 12 volts is missing, replace the warning lamp. If after replacing the warning lamp, the test fails again, the wiring between the warning lamp and the alternator is faulty. The warning lamp circuit is part of the instrument panel and contains some connectors that may cause problems.
2.) Reconnect the D plug to the alternator
Probe the green/red wire from the rear of the connector and use the battery negative post as a ground. You should see 2.4-2.6 volts. No voltage and the previous tests passed, you have a failed regulator. This is an actual measurement taken from a car with a working electrical system.
Engine running, Ignition on, battery fully charged:
Probe the green/red wire from the rear of the connector and use the battery negative post as a ground. You should see battery voltage minus .25 to 1.0 volt. If the battery voltage measured across the battery is 15.25 volts, you should see 14.50 volts
3.) Familiarize yourself with the following application note from Fluke: See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. . You will need to do some voltage drop testing of several of the wires.
attachment.php
How to do the voltage drop testing on the alternator power feed wiring:
Start the car and place a suitable electrical load such as headlights and heater. Begin voltage drop testing with the power out stud on the alternator to the wire lug attached to it. Next, test from the wire lug on the alternator to the stud on the alternator side of the fuse block. Next, test from the alternator side stud of the fuse block to the battery side stud of the fuse block. Then last of all test from the battery side stud of the fuse block to the battery side stud on the starter solenoid.
Any wire or connection that drops more than .25 volts is defective and needs to be cleaned or replaced.
Start looking for these things:
A.) Bad diode(s) in the alternator - one or more diodes have open circuited and are causing the voltage to drop off as load increases. Remove the alternator and bench test it to confirm or deny this as being the problem.
B.) The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges. Do the voltage drop test as shown in the Fluke tech note link. Measure the voltage drop between the alternator frame and the battery negative post. Watch for an increase in drop as the load increases. Use the Fluke voltage drop figures as guidelines for your decisions.
C.) Bad regulator that does not increase field current as load increases. Remove the alternator and bench test it to confirm or deny this as being the problem.
D.) Bad sense wire - open circuit in sense wiring or high resistance. The yellow/white wire is the voltage sense and power for the field. There is a fuse link embedded in the wiring where it connects to the black/orange wiring that can open up and cause problems. Disconnect the battery negative cable from the battery: this will keep you from making sparks when you do the next step. Then disconnect the yellow/white wire at the alternator and the green fuse link at the starter solenoid/starter relay. Measure the resistance between the alternator end of the yellow/white wire and the green fuse link: you should see less than 1 ohm. Reconnect all the wires when you have completed this step.
  • 64898d1292685364-new-alt-battery-still-have-charging-issue-87-93-alternator-wiring.gif
ok, i got my battery issue fixed so i took the car for a drive this evening. it seemed to drive good but it bucked a little but that stopped. maybe it was getting used to the new cpu.
i brought the car in the garage and took the oil cap off when it was running again and smoke was still coming out. it still smelled like gas as well.
any ideas? could the maf conversion be the issue since it did not do this before?
thanks a lot for the help
It's possible... check through all the instructions step by step and ensure that everything was correctly done.
Double check your pin swaps and ensure that you've swapped them to the correct positions.
BE METICULOUS!
