I've had my car out 4 or 5 times in the past two weeks. On two occasions, when weather was cold (once about 35 degrees and other time about 55 degrees), my car wants to buck while cruising. It has always bucked at low rpm because of the cam, but usually once I am around 2000rpm it clears up. It seems to be doing it at 2000+ right now. This is only a slight throttle, when I am wide open it drives fine. It also idles fine. The car is also up to operating temp while this is going on.
I searched through Google and found a few issues that might be relevant. One post described my problem as having a heavy trailer behind your truck and it is always pushing or pulling the truck. It is kinda like that. Some post suggest that it could be the ECT or ACT, another suggested the TPS.
I have checked the codes and I am fine there. The TPS was replaced about 6 months ago, I haven't had a chance to check the voltage yet, but I don't believe it is the TPS. Another post I found mentioned too much timing. I think this may be where my problem is. I run 16 degrees with the spout out. That has been fine in over the summer time, but could this be my issue now? Do I need to back it down to 14 degrees or less?
Thanks for any help!
Joe
Joe
