idling problem
eugenewilhelmjr
georgia
my 5.0 the idle keeps jumping up and down, runs stable at 1,200 rpm but when I try to lower it it starts to jump up and down what can I do to fix it, I set the timing, adjusted voltige regulator to .98 and still wont idle loike it should
EEC controls idle. Hunting idle can be due to dirty or faulty IAC, Idle Air Control valve.
BTW, you did not set the voltage regulator to .98V, it's the TPS. Adjusting it has no effect on idle.
See the "Surging Idle Checklist for help with all your idle/stall problems. You can guess at the problem and throw parts at it, or you can use the checklist to help you find the problem quickly and inexpensively.
The quick and easy way to dump the codes is in there too, and all you need to do it is a paper clip! The first two posts contain all the fixes & updates. At last count there were 24 possible causes and fixes for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
Really? Did you adjust your VR to .98 or your tps to .98 cuz just incase you didn't know your voltage regulator isn't adjustable and has nothing to do with your idle. So either ask "uncle jessie" to refill your headlight fluid or see if "daisy" can calibrate your knifilin pin. Or just sell the fox and buy a honda.
hey man theres no need to be an a hole Im the one that built this car from scrap, Im good with mechanical issues just not good whith stuff like this
Here's a picture...
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Wiring & Engine Info Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
