What is this?
JordanB21
804
27
29
Killeen, Texas
Well I took out my air box and saw this unplugged because its missing a crimp. Something related to the vacuum lines I think. and would this cause my car to have a check engine light occasionally? such as oh say high speeds?
Just wanted to know what it was and what it does, thanks
:shrug:
Where is it coming from?
There is nothing there for it to plug into.
Is it your IAT sensor lead?
Looks too short to make it there, but other than the MAF, that is all that is in this area.
If it is from behind the strut tower, there is a small device back there with a vacuum tee from the top, and wires plugged into the bottom.. but I think that has a small square connection, not round.
Secondary Air Injection stuff for the smog pump.
So no big deal?
The thin black hose connects to I think the throttle body. It connects to the smog pump so yeah:p
You are referring to the electrical connector that's dangling, correct. That should be the connector to the AIT sensor. When you removed the air intake tube was the AIT sensor not there or was it just unplugged. The sensor will be threaded into the air tube that's why you don't see the other end for the connector.
Reactions: ratio411
Oh no, I should've moved that more out of the way. I unplugged that myself:p
The smog circular thing was what was unplugged, missing the crimp.
That's what it looked like to me....
And, yes, if it is the IAT sensor connection, it will probably set a CEL...
Have you pulled codes yet?
Did you see an AIR code?
If you pull codes, look for an EGR code - it would fit the times your CEL is coming on.
As to your codes, those both have to do with the emissions system. Leading from the driver's fender near the air filter, you should find 4 colored plastic hoses. Two lead to emissions parts under the intake hose; the other two lead under the intake and hook to the EGR valve and the intake. Basically, these parts work off of engine vacuum - if they are cracked, the system won't work right. It's also common to switch the hoses between the EGR and the intake, since they're right next to each other. The green one goes to the EGR, the red goes to the intake.
This was in response to my question about these codes months and months ago, codes were 311 and 314
So yeah, it is an EGR code, originally I thought it was the EGR, so I pulled another one off my old engine, cleaned it out with carb cleaner and it was the same result with the codes coming on occasionally at the high speeds.
And where has Chythar gone? I haven't seen a post by him in a long time! Maybe I just miss them :p
LMAO!
That's the way to show us!
I was confused because the only thing unhooked the pic was the electrical connector!
Sorry for any mix up it caused your thread, but I really didn't see anything else unhooked.
Yeah, probably shoulda took the picture when it was unhooked and the connector moved:p
Who, me? I mostly lurk these days, though I do chime in now & then. I haven't done anything new on my 'Stangs lately, so I don't have anything cool to post either. I did pick up a 2002 center console recently, I'm waiting for the weather to warm up so I can paint the console to match my interior.
Did reconnecting the hose get rid of your check engine light?
I don't know yet, I need about an hour of day light to finish my fan PWN install before it's drivable. But lets hope
I still need to grab a center console w/cup holders. But yeah I was just wondering if you fell off the planet since your last thread about the tablet in dash install.:p good to see you!
The vacuum control module that controls both the EGR and those air valves is all interconnected. That is possibly why it through an EGR code.
Kurt
Yeah that's what it seems. I'll let you guys know after I take it for its first drive in months in a few days. :D
Just noticed this one too, some other thing that is in/on the same line as what I just showed.
For whatever reason this vacuum line was cut, not that I care, but if I still get the trouble code I'll just assume it's because of this:p
