flywheel swap info on 67 mustang 200 cid
has any on put a newer ford 200 cid fly wheel on a 67 ford 200 cid
yes it has been done, the swap is direct. there are clutch kits available for the recessed flywheel if that is what you have, although yours being a 67 you should have the flat flywheel, and the clutch kit from the later car should bolt straight up to your 67 flywheel.
