Lets see some Pic's of your V-6 Mustang
Bullitt347
I have been doing it wrong this whole time
4,040
3,069
204
Middle of Maine
Do not see hardly any pic's of anyones V-6 stang, so I will start with a pic of mine and see if this gets the ball rolling on showing your ride. This pic is not in the best light or at the best angle, but it is a start.
Bullitt 347, what all do you have done to yours?
2003 3.8L
A/M CAI
BBK 65mm TB
Ported Upper and Lower intake Manifolds
Pacesetter L/T's
Pacesetter o/r X pipe
Pypes Violator tail-pipes and mufflers
Screamin Demon coil packs
PDL 10mm plug wires
NGK Iridium IX plugs
Spec stage 2 clucth
Tri-ax short throw
93 Octane Bama tune
GT rear bumper/wing
GT 8.8 rear end w/ Ford Racing 3.73's
2003 3.8L
A/M CAI
BBK 65mm TB
Pacesetter L/T's
PDL 10mm plug wires
Spec stage 2 clucth
Tri-ax short throw
93 Octane Bama tune
GT rear bumper/wing
All that money in mods and you probably don't even break 200rwhp. I admire you building your car but I don't see why anyone would waste money performance-modding a pre-2011 V6 Mustang.
Reactions: usaf_branham
2003 3.8L
A/M CAI
BBK 65mm TB
Pacesetter L/T's
PDL 10mm plug wires
Spec stage 2 clucth
Tri-ax short throw
93 Octane Bama tune
GT rear bumper/wing
I have H&R sport springs
Maximum Motorsports sub-frame connectors
UPR rear lower control arms
Installed Trac-lock rear diff with stock 3.27:1 rear gears
Accufab 70mm throttle body ( upper port matched to T-Body)
Steeda cold air kit
SCT tuner
Steeda underdrive crank pulley
MagnaFlow dual exhaust cat-back system
GT rear bumper cover (thanks to an idiot that rear ended me)
QA1 caster camber plates
QA1 bump steer kit
Mach 1 front chin spoiler
Grill delete (Late Model Restoration I think)
Boyds 18x10 rear wheels 275/45/18 555 Nittos
Boyds 17x8.5 front wheels 225/45/17 Michelin Pilot Super Sports
Engine/trans/rear diff switch to synthetics
MSD 8mm plug wires (stock wires gave out at 148K miles)
Front leather seats from a 2000 GT (Had stock cloth seats)
Car gets 32+ mpg at 70 mph highway.
Because I can............this car runs, drives and gets better mpg than stock and it does not look like grandma's DD.
I also have a modded 08' Bullitt for my street HP bug.
I am almost done with my 89' Saleen drag car than will sport a 1200+ HP 358cid small block Kenne Bell supercharged engine for my real fix on HP addiction.
The 01' V-6 car is the perfect DD that does not look like the same old, same old.
But mostly I modded it because I can.......and because I wanted to.
Another side note...........the 01' V-6 5 speed Mustang of mine out handles my 08' Bullitt. The Bullitt has 18" Enkei wheels (a lot lighter than the stock wheels) Steeda ultra light springs, HP Motorsports rear upper and lower control arms and panhard bar, Steeda radiator support and JBA headers, X-pipe, Moroso axle back mufflers and a custom tune along with the Ford Racing cold air kit and Steeda underdrive crank pulley. Now in a straight line the Bullitt kills the V-6 car so bad it is laughable. but put them through some corners where HP is not an advantage, the lighter V-6 car is so much quicker it leaves the Bullitt in the dust. The 01' V-6 Mustang is 500 lbs lighter than my Bullitt!
Reactions: Kilgore Trout
I just wanted to build something that most people wont, a lot of people look down on the 3.8's but they are great little street cars and can easily be built to keep up with the GT's
I will have to disagree. The 3.8's are horrible motors that underperform against even a lot of the smaller 6's at the time (and even against some 4cyl motors). 4.6 2V's are by no means excellent motors themselves, but you're talking about a difference of at least 50-60rwhp/80-90rwtq and 2-2.5 sec in the 1/4. There's no way the 3.8 is going to make that up without going FI or spray.
Correct me if Im wrong....but swapping to heavily machined stg. 3 heads, complete upper/lower intake, and a gnarly cam isn't "easy" or "easily". That's some pretty heavy work. And the 80hp gain is at the motor, not the rear wheels. Basically all that to get the 3.8 to near stock 4.6 2V power levels.
Don't get me wrong, I have nothing against V6 mustangs. Without them there wouldn't be any GT's or Cobra's. I just don't see the point of performance modifying them. But its your car and you obviously have the right to do whatever you want with your money :flag:
Not alot of people build V6 mustangs either, thats what draws me to doing it so much i know its gonna be alot more money to see the power levels that the 4.6L can reach with bolt ons but the stock 3.8 isnt that bad in comparsion to the stock 4.6 2v either. The 3.8's came stock with 193 hp and 220 lb-ft and the gt had 260 hp and 300 lb-ft in the 99-04 model the 4.6's arent the baddest motors around either
