Trans Go Or Baumann
Ha! VD.. I'm kinda looking into the silverfox VB, not the constant pressure but the spt1. The description says one can adjust shift points in 800 rpm incraments via a screw on the vb. I'm not quite understanding this really since I thought shift points in the aod were controlled by the TV pressure. I'm not much of a tranny guy at all, its all foregin to me. But I do hear that Tranny's have VD. Oh one more thing, do y'all think the entry level silverfox or any for that matter are worth the 270 bucks? I mean after all all they are are a tweaked used stocker. One could buy a pa street/strip for a little cheaper or for a good deal cheaper you could buy a shift kit and put it in your vb yourself. Would it not be the same thing? I don't have any experience w his product or know anyone who does so I'm not bashing it I'm just curious. The reviews on other forums say its pretty good,(save for one I've read) but I haven't read where someone had a cheaper shift kit and then switched to the silverfox and said that the fox blew the transgo outta be water for example. They were only comparing it to a worn stocker. Oh and allegedly the silverfox comes from the "factory" set to shift at 5800 from 1st-2nd
if im understanding how these things work correctly, the governer is what controls shift points, and it can be manipulated.
as far as an already modified vb (doesnt matter through who), you gotta remember that taking your car somewhere and having a shift kit installed is gonna cost about $300 (or more) in parts/labor. add in that the silverfox ones are basically custom built for your application (4r gearing in aod, custom shift points/firmness), and its really not THAT bad, but yes, there wont be a huge difference between it and just putting a shift kit in for the untrained eye.
Give this a read http://sbftech.com/index.php?topic=31131.0
got her out.. A lot of little balls and springs. Pretty easy soo far. Had to quit for the afternoon. Back at it after my son goes to bed.
Sent from my iPhone using Tapatalk
Well, after some unsuccessful internet searching I decided to make my own. Used some spring steel I had laying around. Made a couple variations of the clip, hope one of them works.
Just finished up the install. I did not put the high rev portion of the kit in though. Prior to the kit the aod was sloppy on downshifts, now it responds right away and has a little kick going into 2nd and 3rd. Chirps 2nd easily. Have not tried 3rd yet. It shifts at about 5500 on the stock tach now . Before it was 4800 or 4900. I am going to Cecil county drag way next Friday night so we will see if it made any difference. I ran a 14.6 last time I was there.
I was cleaning up my mess from this project and I noticed I put the first half of the hi rev kit in. There are 2 sections. I did not put the governor part in. This is optional. But the shift point 1-2 has dropped a little to prob 5200 or so and 2-3 prob 5-5100. Don't know why but the kit says it should be slightly over 5 k so I think the instructions are accurate.
I shifted manually last time too. It shifts faster and harder with the kit, but I also have under drive pulleys on the crank and water pump. They were not on the last time. Shifting at a higher rpm (5500) resulted in higher et's. I think the car likes the 5k- 5200 shift better
