Fox Shock Choices???????????
How much you adjust the shocks at the track would depend on track prep and tire choice let alone basic chassis set up. On the street you will find that one sweet spot that works great for DD. Otherwise, you really do not use the adjustment much at all. The best thing about adjustable shocks, is that it is like buying upwards of 10 different shocks (or more) at once. You do not have to worry about buying the "wrong" shocks, or ones that don't do what you want them to do.
I see
I've read alot of good post on Strange shocks in rear and now starting to see alot about QA1's. Which is better launch and hook? Just curious
I have coil over shocks on the back and choose the qa1's. my rear suspension is far from stock although I've seen them used on a more stock setup successfully. As far as adjustment goes, it's not something that gets played with often but is warranted to be able to make the proper initial adjustment.
I took a look at the Strange pieces, the prices are extremely reasonable, front and rear. $120 & $70.
I was going to order a set but ran across a part number issue and couldn't decide which P/N to order. I have the SN95 Disc brake conversion using the 95 spindles on my 86GT. I wasn't sure if I should buy the 1995 p/n pieces or 93 era parts. They don't show any Part Number for the 1986 in OEM form for the struts.
There must be some difference...
iirc, the oem shafts are different lengths (sn longer), but dont quote me on that.....you'll want the fox stuff either way. i dont think you'll see too many aftermarket companies making different ones for these two applications
I figured there must be something different, hence the separate part numbers. I hope it's just the length issue, but I was surprised to see that they didn't have a part number listed for the 86GT - something must be different there also..... ???
EDIT: 87 - 93 Struts on an 86 Mustang
I did some research and discovered: Most 79 - 86 Mustangs come with a 1" wide spindle spacing that mates to the front strut.
v8 87 - 93 cars come with a 3/4" spindle spacing. 4 cylinder cars retained the 1" spindle spacing like the 79-86 years.
A lot of aftermarket strut suppliers will make their struts with the 1" spacing and will provide spacer bars in the package to make up the 1/4" difference when being used on the 87-93 cars.
Options for you 79-86 cars: Upgrade your spindles and rotors for a wider range of parts selection and a bit better braking performance as well...
