You sir did what i ended up not having time for lol and the only thing i despise about my tuck is i can still see loom between the trans tunnel and back of the intake i mean most people wont notice but i do everytime lol
The engine is completely wired. I'm in the process of bundling up the harness and getting it into some wire loom. Some wires are too long and need to be trimmed and re-terminated. The only thing that I may need to change is how the fuel pump is wired. The panel only has a 15A fuse, but the Fuelab pump requires a 12GA relayed circuit and a 25A fuse. I have an e-mail into the company that made the panel to get their opinion on how it's best to wire the pump. I'm thinking another relay will be necessary. More pictures will be up tomorrow. Next will be running the feed and ground from the battery to the front of the car.
What are you using to wrap the wires/harness in? Please tell me its NOT that oil magnet convoluted stuff.
Isn't the 25 amp fuse, installed in-line of the fuel pump? If so, the relay itself would be the only fused through the panel and it doesn't require much juice at all.
The fusing is always done directly off the 12V source feed to the relay, not off the feed wire directly to the pump. Here's the schematic for the Fuelab pump.
What I can do to make this work is use what is now the output to the pump (stock color is pink/black) as the signal wire (blue wire above) to a new 30A relay. I can pull a fused 12V source off the battery and run it to the relay. I believe I need to keep the stock relay one way or another because of the way it's wired into the ECM. Unless the panel manufacturer has a more efficient way to do things, this will work. This is how any aftermarket in-line pump is wired in. The only difference for me is that I won't be powering an in-tank pump as well off the stock relay, so it's a little redundant to have a relay powering a relay.
I'm also going to run a wire from the pump feed up to the dash so I can have a 'pump on' indicator light. The last thing I want is not knowing if I lost voltage to the pump.
I got one word for you..............Thanks Mike. Suck up all you want! And the battery cables are #1/0, for the record
I actually didn't even think about the molding screws, but that rocker channel is so deep that the screws won't come anywhere near the cable. The cables are laying on the bottom of the rocker, and there is probably 3" of clearance to the top. I'll double check the screws when I attach that molding to make sure they aren't excessively long anyway.
I had thought about running all the ECU wires through the passenger side rocker, but the idea of fishing 50 wires (one at a time) through that small space was not very appealing to me. The harness will flatten out under the carpet anyway.
