Noise While Steering 1998 Mustang Gt
Nick D
38
New York, NY
my 98 gt has started to make a noise while steering, the sound wasn't so bad a week ago but now it's very loud. it sort of sounds like something is dry/squeeking, not girding though. im not exactly sure where it could be coming from and how to fix it.
Need more info. Is is coming from the steering shaft area, the steering colum, the wheels, the steering pump?
definitely not the wheels, or the steering shaft, but i most likely is coming from the steering pump or column. i'm going to change the power steering fluid first to see if that helps. you only hear the sound when you steer the car and it sounds like it is dry without any lubricant
Its may be the fluid level is overfull or u have to service ur steering system add new oil . Use only motorcraft .may be ur oil is get so dirty to make the pressure stable. to much pressure inside which cause the steering to produce sound and make sure that there's no pipe leakage ...if then brake padel will also make sound when u hit brake.
