O2 Bung Placement
JD1964
there is enough sticking out to grab on to
3,647
1,670
194
Maryland
Disregard concerns with cats when answering this question.
I'm choosing where to weld in the o2 bung for a wideband. I have shorty headers and xpipe. The x joint in the exhaust pipe is just behind the bell housing and right under the gearbox. I was thinking of putting the bung aft of the xpipe connection. This way the single sensor could be sampling a mix of both banks.
The instructions in the wideband kit say to place the bung at least 24" back from the engine. Since my xpipe connection is closer to the front anyway, do you think theres a problem with mounting the bung just to the rear of the x connection? The bung would be just prior to the trans cross member, which is at least 24" behind the engine.
The bung needs to be in the 10 - 2 o'clock position to ensure moisture (condensation) doesn't pool around the sensor element. The 24" from the engine can be read as 24" from the collector flange. The intake flow due to design causes the drivers side to run leaner than the passenger side. Because of this most will locate the WB O2 sensor on the driver's side on the mid-pipe.
∆∆∆ This exactly!
