How much different is the shift/feel of a short throw shifter? I have heard varied opinions from one extreme to the other. Just curious what I should expect. TIA.
Mine has a steeda tri ax installed by PO. I'm having some trouble finding gears. No sure if it may need an adjustment, or bigger issues to explore. Going to check the stops today. Any other thoughts?
I also feel the longer Hurst would provide a great feel for a daily driver. Less effort along with the improved lower shifter design over stock. The trade off is the speed of the shift with the longer throw. That being said I hate the look.Maybe previous owner installed the tri-ax handle only?
Any of the real aftermarket shifters (Pro5, Steeda, B&M, Hurst etc.) when adjusted properly should provide a very precise and solid feel.
I like Hurst.
MGW gets great reviews, but "I" don't trust all the adjustable points in the handle when it comes to racing.
Further more, I like a longer handle for racing as well. The little stubby ones work, but are too far out of my reach/comfort zone.
I offer those points for your consideration, not to start an "they work for me" debate.
I think the added leverage ratio more than makes up for the longer throw length with regard to speed between gears... yes, that's it, I am convinced.I also feel the longer Hurst would provide a great feel for a daily driver. Less effort along with the improved lower shifter design over stock. The trade off is the speed of the shift with the longer throw. That being said I hate the look.
If you still need help msg me the info about your car, where you bought the shifter, and the shifter part number. I will help you get any needed information.Mine has a steeda tri ax installed by PO. I'm having some trouble finding gears. No sure if it may need an adjustment, or bigger issues to explore. Going to check the stops today. Any other thoughts?
