R/F door does not open from the outside only the inside, seems to have a door lock actuator thats all binded up. drivers door had a broken outside door handle, but if you pullon it just right at the right corner it would open until i went to get in it last night and it all popped off, i can see in the door and the spring part from the right side of the handle right closest to the lock cylinder where it would pivet up and down is in there i can see the rods for the lock and latch. question is now how can i open the door so i can replace door handle. its a coupe and i have no door keys previous owner lost so i need to replace locks. but i need to get in so i can replace this door handle
. Go get yourself a metal coat hanger . Make a loop on the end . Pull the door frame back enough to get it past the weather stripping. Get the loop around the door handle. 3 quick fast pulls should make the lock come up and the door open. Yes i have locked my keys in a few times back when the car was a DD
