Digital Tuning Cai And Throttle Body Swap
03Cavillo
stl.
03 mustang gt. Put bbk .78mm throttle body plenum one piece and cold air intake. Said would work with factory setting now idling off and is a whistle when throttled normal coming from throttle body.?
Depending on the sound, it may be a vacuum leak. Spray a little brake cleaner around the plenum and intake. If the motor revs up, that is where your vacuum leak is.
But there are ones that have that whist
Thanks will try.
Some whistle or sucking noise is normal with a CAI. When I installed my CAI it would make a slight whistling sound on moderate acceleration (sounds like when you try to whistle while inhaling), after installing a tb and plenum it became more of an audible "shoop" noise, which is normal. My idle seemed like it was out of whack as well right after installing the tb and plenum, but as long as your IAC is working right, the idle should be adjusted back to normal.
Did you follow the manufacturer's recommended procedure regarding HOW to set the idle stop screw?
Here's some more information on how to trouble shoot Idle/IAC issues.
http://www.stangnet.com/mustang-forums/resources/troubleshoot-iac-idle-problems-1996-2004.13/
