No Fuel No Spark Help!!!
Jly154
33
Nebraska
hey guys so I'm new to this forum and fairly new to mustangs so about a month ago I bought a 94 gt and it ran fine till I had to replace the ground from my battery to the block before that i had to jump start it twice I took my car to the carwash got home parked it and it wouldn't start and sense then I have no fuel or no spark I replaced the ignition control modual, starter, starter solenoid and I read that it could be caused by the pip sensor going bad in the distributor. Yesterday I tried starting it and nothing so I took out the spout plug and I got spark with it out and it even tried to start with some starting fluid but now I'm out of ideas on what it could be.
The fuel pump should come on with the key. Have you checked all fuses and relays? I would start there. I'll bet you don't have 12v going to the fuel pump.
I don't get anything that I can hear except the fp relay clicking up front and no fuel pressure at the schrader valve at all I have yet to check voltage at the pump I found a Diagram on how to make it cycle and that didn't seem to work either so I'm not sure
Try tapping the ccrm with a mallet. I've seen contacts stick before. Not a long term solution but will rule out if they are stuck open.
Where exactly is it located I haven been able to find it but I only looked once it's getting cold here (highs of 25-30*) so I haven't been too motivated to do a whole lot with it lately
