Power Window Issues
Scott Murphy
34
14
18
Hey. I have power windows in my 84 GT hatch that do work. New run channels have been fitted but don't solve the issue. The window gets about 1/4 way down and drops before continuing winding down. Can anyone attribute this to anything? The glass was previously broken prior to buying the car. Not sure if this has stripped the gears or something trying to get them down as the car was broken into. Cheers
Here's some help, the most likely cause of you problem is the rollers inside the window motor.
Power Window tips & tricks
Motor removal & replacement
Remove the door mounted speaker & the upholstery panel to gain access to the motor. There are 3 screws (5/16" hex head, I think) that secure the motor in place. Remove them and the motor comes out without any problems. Once you remove all the screws from the motor, and it falls away from the gear teeth on the arm for the glass, the glass will move up and down. You may need a helper to hold the glass once the motor screws are out, since the gear on the motor holds the glass from sliding up or down
Motor interchange
The motor is the same for left side or right side, only the gearboxes are different. If you can't find the complete assembly for the side you want, you can get either side and use the old gearbox on the new motor.
The window motor gearbox has 3 plastic rollers that are a safety clutch to prevent possible injury if the window is rolled up while something or someone is hanging out the window. The plastic rollers will often disintegrate into chunks of plastic and the window will no longer roll up or down. The motor runs, but the window does not move or only move a little.
The Help! section of your local auto parts store will have the replacement plastic rollers.
See NAPA Window Regulator Gear Plug
Napa p/n BalKamp 6651524
Cost is 9.49$
AutoZone and other auto parts stores see Dorman 74410 / Window Lift Motor Gear Kit
Cost is $7.99
Power Window Wiring Diagrams
Diagrams courtesy of Tmoss & Stang&2birds
87-92 model cars power window wiring:
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 model cars power window wiring:
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Wiring & Engine Info Everyone should bookmark
Reactions: Scott Murphy
Motor interchange
Cost is 9.49$
Cost is $7.99
Much appreciated. I will get onto it. Sounds like a fairly cheap fix just replacing those plastic rollers if I read correctly?
Yep....it was the rollers. Just ordered a set for both sides from the states that are machined aluminium. Should last a while longer! And they were the cheapest on all counts incl shipping to Australia. Cheers guys again.
