How To Avoid Issues With 17x8 Cobra R's On An 89 Gt?
CopNaStang
20
I have an 89 GT vert. Im slightly lowered, maybe an inch. I currently have stock turbines with BFGoodrich rwl radial t/a's 225/60/15. No rubbing of any kind. I was wanting to add the 95 Cobra R style wheels, but what tire size are people running so the dont rub ground effects? And with your size that doesnt rub the ground effects, does it rub the inside suspension? Has anyone done a proper tire size and steering limiter combo that has no rubbing at all? Do the dustcaps need to be hammered for the centercaps to fit?
4-lug? or 5-lug?
The 4 lug versions are sizes so that there really isn't much of a issue with contact provided not lowered too much.
5-lug versions all depends on what offset you pick. If sticking with 17x8 rims, go with offsets similar to 94-04 mustang 17x8 wheels.
Also, you'll need a 5-lug conversion obviously, and may have fitament issues up front unless you do Sn95 front spindles and brakes
Basically just a wheel swap. From stock to 17x8, but I want to know the tire sizes up front that I dont have rubbing issues, especially on ground effects. The only wheels Im considering aside from keeping stock is 17x8 Cobra R style or 17x8 Pony wheels.
Reactions: smokin joe
This was with 245/45/17 fronts and 275/40-17 rear. 17x9 wheels with eibach springs,struts and shocks with a UPR bumpsteer kit and mm cc plates. No clearance issues
Edit: with 17x8 keep the front tires around 245/45 or 235/45 and you'll have plenty of room. It's a very common size. I highly recommend getting some cc plates and the UPR or steeda bumpsteer kit. It really helps with alignment and allowing the front end to not "jump" around with bumps in the road etc. That can be a problem with lowering springs. I have since gone to coilovers and even lower frontend without a problem. I am going to raise it back up a 1/4" or so for a cleaner level look.
every car is different- You can't expect someone to tell you 100% what tire is or is not going to rub on your car. Has your car been lowered, in an accident, what offset wheels,etc I have 245/14/17 on my 90 and it rubs only when you lock the wheel. It does not have rack limiters on it yet- too lazy to put them on lol
There were only two wheel choices I gave, and my car hasn't been wrecked. Lowered an inch at most. Ok cool. No issues with the dustcaps hitting the wheel centercaps on the Cobra R's??
Sounds pretty promising.
I've got 17x8 with 235/45/17 on my 88 LX. Not really lowered due to the Mach 1 springs, but I'm comfortable I could get 245/45/17 up front that it's what I'll select the next time I get tired.
Sent from my big ass iPhone 6 using Tapatalk
