Turn Signal Question.
Benz510
171
70
38
Oakland California
Hi guys,
Just got my fox on the road. Some of u know this because of my recent posts. Anyways, i have a question. Would anyone now the cause of my left turn signal staying solid only when the headlights are on? They blink fine during the day when I'm not using my headlights. I only doscovered this last night while driving home from work. I even replaced the bulb just in case and still the same problem. The right turn signal works as it should whether the headlights are on or off. Any info or suggestions would be appreciated.
Thanks,
Ben
Couple more questions. Do your high beams work?
Also, are the exterior turn signals lit when the headlights at on, or is it only in the dash?
Do the hazard lights all flash when the headlights are on?
Hazards work..The high beams don't work at all. The passenger side turn signal bulb actually blew when i tried to use the highbeam. It's sounding like something with the wiring. Any suggestions?
@Benz510
Check out the passenger side light ground - it is for the parking lights, headlights and turn signals.
