Post pics of how your foxbody currently sits
too many sweet foxes in here...
That's my junk for now... Still need to install the coil overs, I want it lower but need to fix my crappy exhaust system install...
My mid pipe was the same as yours after I installed it. $20 at a muffler shop fixed it real quick. My hangers had to be shortened. FYI, be prepared to move your brake lines if installing coil overs up front. That's what I had to do when I installed my MM coil overs.
Sweet car bro!
You from Toronto area Steve? I swear I've seen this car over on GTAMC?
...if so, you will give me first crack at those wheels when you switch them out, right? ;)
Would u happen to have a write up on your retroed headlights? Or could u share the specs on them like what projector and shroud? How bad was opening the headlight?
Sent from my XT1650 using Tapatalk
I don't have a write up but I got a set from LMR, heated them up and split them, opened up the bulb hole to accept the Morimoto projector and sealed everything back up. It was a bit of a process but for my first time tackling this, it wasn't that bad.
Reactions: nickpic
I think I had asked you but - 245/45 up front ?
I love the projectors to . That's an idea I think I really need to revisit
Actually they are 255s up front. The projector project wasn't hard but it definitely expensive! It came together nicely and I know you guys' will too!
