- Mar 2, 2015
- 6,950
- 5,826
- 213
Hey man, all you have to do is get a piece of sheet metal and sandwich it between your oil inlet and the turbo with a hole drilled thru for the restrictor. If you don't have the flanged fitting, get some 1/4 thick aluminum to make the flange and drill/tap it to whatever pipe thread you need to screw an npt/an fitting into, then put your orifice restrictor under the flange. Make extra gaskets from parts store gasket matl. Easy peasy.
I have some scrap aluminum that will work for that. Thanks man ! Saved me a couple bucks.
i
