Headlights A Bit Lame
I think this answer is two fold...to get optimum brightness upgrade to a better housing and add relays so they get full voltage...or do an HID retrofit
Those HID kits can be just as harmful as helpful. They can be too bright, and mess up your peripheral vision. Or they can blind an oncoming driver. They can also over focus. The engineers at Ford spend actually spend a lot of time perfecting exterior lighting; far more time than an aftermarket company spends. Brighter isn't always better. The color of the light is more important than the intensity.
Kurt
Luckily I have a set of OEM lenses on hand. They are from my 92 hatch. I had gotten a good deal on replacements for that car years ago and kept these in the shed. Slightly yellowed but maybe they’ll clean up. What are the frugal tips to clearing them to extents possible?
I plugged one of them in to the car and wow! Instantly I could see an improvement without even driving the car. You can see in the picture how the light fully floods the lens evenly and brightly compared to the junk aftermarket.
As far as the aftermarket lenses are concerned, I’m not even sure I want to sell them. I’d almost rather put em down range for some fun during target practice!
Reactions: Noobz347
Cleaning a headlight lense.....oh my!
John, you can go through the sanding and buffing routine. It will only last for a few months. Once the plastic begins to degrade, you're screwed.
Unless! You sand it down with 400-600 grit sandpaper, spray an adhesion promoter and reclear the lights. Sometimes you can be too late and can't sand out the yelllowing.
I bet you'll be fine though,
Reactions: 90sickfox
Dave, soon I’m gonna be tapping your expertise on fixing paint chips. Man I’m such a tight wad! I swear, one of these days I’m gonna take one of my cars to an expert like you and say, dude, just do it!
My black ‘92, id love to see it in silver with custom black accents
Reactions: Davedacarpainter
For sure...but a properly done HID retrofit can perform quite nicely (once set with proper cutoff and aimed etc)...ive seen a few done very well....but it takes alot of time and certainly isnt the cheapest route...i will be doimg this myself most likely over this winter sometime and will post up pics etc if i end up having the time to tackle the project.
Get a front bumper from a period correct Mustang at the JY, the more beat up the better. Install the headlights along with some power LEDs a power supply and micro controller.
Hang it on the wall in the garage. :spot:
This project might be a good one for that:
https://create.arduino.cc/projecthu...desk-light-7ef416?ref=tag&ref_id=led&offset=3
I may have to consider this for my own garage. :chin
A friend of mine installed HID headlights in his mustang....that night he hit a deer. Guess they were brighter.....blinded the hell out that thing.
Reactions: killer5.0
Go back to OEM lamps. Install a relay circuit. You will be surprised how bright even a "regular" halogen (H9004) bulb will be. If you're going to do an "HID" conversion do it right. Don't drop an HID bulb in a housing meant for halogen. That's the idiots guide to blinding other people and not being able to see **** yourself.
Reason the lenses "yellow" is the UV protection blended in with the plastic has degraded. You can try removing the yellowed surface and the coating with a UV protectant but that's only going to get you a limited time before they yellow again. The plastic will again become damaged by UV exposure.
Exactly HIDs need to have an appropriate projector retro fitted into a fox housing...otherwise you get ridiculous glare etc...
Aftermarket headlights....well..suck. They don't project the beam correctly, not that the stockers were much better. Those headlights were never factory, so you are relying on the supposed ability of a company to properly design and validate the reflector, and then build them in china with very loose QC and meet strict roadway standards that OEM's spend millions on design to achieve. So you need to take their abilty to project with a grain of salt.
However, part of the issue coule be electrical as well. The intensity of the bulb depends on the voltage it receives and this all depends on the wiring feeding it and the grounds. A good solution is to rewire the headlights so that the original wiring triggers a relay that is feeding direct voltage from the battery and a good ground. This will ensure the brightest beam from the bulb.
Thank you for bringing up the relay. This is something I want to do now.
The guy in this video has a great explanation of how the relay works better and how the factory wiring is sub-par.
View: https://www.youtube.com/watch?v=4d0ikK5IQa0
They don't look bad at all. Wetsand with 2000 grit, and then polish with Mother's Mag and Aluminum polish. Take you 10 minutes. They'll be good as new.
Kurt
Did voltage check at headlight socket. At idle of 800 under load of headlights on and heater blower on high, 13.10v. Heater blower off, 13.81v. At 2000 rpm, holds 13.9 no matter the load.
Lower than at battery posts but still adequate
